Hi again, I'm chasing part numbers for replacement filters for my e27n with a Perkins p6. Air, oil, fuel and best place in Australia? And if any body has a part number and brand for the fan belt
Cheers Toota
Filters
Re: Filters
Toota,
If you can give me some information, I might be able to help you.
Oil Filter - when you remove the bowl does it still have a brass cage inside the bowl (filter is inside the cage). It should have Vokes on the head piece.
Primary Fuel Filter - is it Vokes or CAV?
Secondary Fuel Filter - will be CAV, but I need to know whether it has BFA 5 stamped on the head, or BFA 11.
Primary Air Filter - go to a Daihatsu dealer as one of the little 4x4's uses an element that is very close to the Fordson (there is no direct replacement).
Fan Belt - Goodyear No. V1167. The original Ford Fan Belt - FoMoCo No. 0070001.
BarryM
Re: Filters
Hi Barry M
Thanks for your time
The Primary fuel filter is Vokes Aust E50F M\54
The Secondary Filter is stamped as BFA11
The Oil filter is a vokes and it does have a brass cage
Do you know much about the Fordson Decal on the fuel tank for the Aussie models?
Re: Filters
Toota,
The Oil Filter is a Fleetguard LF599.
The Primary Filter is a Ryco R202V.
The Secondary Filter is a Ryco 2047P.
Primary Air Cleaner is a Micro WA117.
Will send you a PM regarding the decals.
BarryM
Re: Filters
Thanks Barry
Ill check my messages
Cheers Toota
Cheers Toota
