Model N front wheel bearings
Mark P
Post by Mark P »
Hello, can anyone give me the bearing numbers for the Inner and Outer or the sizes.
I know Cotwold Vintage does them but they are very expensive!!
Tim W
Post by Tim W »
if you can measure your old ones (or the axle and hub diameter)
give "The Bearing Boys" a call, (01233 822150) they'll probably be able to help.
Tim
1947 E27N, some grey ones and a 1953 AJS 350...
Godfrey.harmer
Bearings
Post by Godfrey.harmer »
Failing that Tim just take one of your sets to a bearing supplier and they should be able to match them, thats if there is a current size that will do the job.
regards
Godders
Godders
BarryM
Site Expert Team
Site Expert Team
Post by BarryM »
Mark P,
Your old Bearings will have the numbers stamped in to them and those numbers are still current. Inner Cup and Cone should be stamped 350 & 352. Outer Cup and Cone should be stamped 14118 & 14282. Check your Outers as there was a change made towards the end.
Hoffman, Timken, SKF, etc., all used the same numbering. Any good Bearing outlet will carry them as a Stock Line.
BarryM
