Hey people!
I've got a question: Can you see from the outside what kind of gearratio is fitted in a Fordson N (Standard) gearbox?
I can buy a Fordson N Industrial and I would like to know if it's a "fast" or a "slow" one...
Hope to hear from you guys!!
Greetings,
Martijn
Holland
Gear Ratio Fordson N
Re: Gear Ratio Fordson N
I know that the F's had different ratios. Just how many I am not sure. The N is similar. Dandy Dave!
Martijn,
Remove the Belt Pulley and you will see the Transmission Plate. Locate the Reverse Idler Shaft. It has a Peg above and a Peg below. If the Pegs are pressed in, then it is a High Speed. If the Pegs are held in by castellated nuts, then the Transmission is a Low Speed 4.3.
BarryM
Thanks BarryM!
I will have a look for it...
This again proves that a forum like this is very helpfull!
Greetings,
Martijn
Greetings,
Martijn
Another way to check is to remove the spark plugs, select top gear and wind over 10 times. low ratio will move about 3 ft and high ratio 7 ft.
This is based on 28" wheels. it is not perfect but gives a quick guide if you are not able to remove covers.
Richard
Richard
