Hello all,
I have recently purchased a Fordson N Grader that has had a replacement engine fitted this is a later version with the starter motor mounting, however as the tractor is 1937 it does not have the clearance in the flywheel housing to fit a starter normal motor, does anyone know if there is a modified alternative that I could fit to the tractor as the crank handle under a standing platform in front of the radiator looks like it would love to break my arm!
Mike
Fordson N starter motors
