MY E27N WONT START :-(
Posted: Sat Nov 05, 2011 4:36 pm
by The Tractor Kid
HI
I am having trubble starting my e27n there is a spark and i have striped down the carb and cleaned it, just not sure what is up when you turn it over by hand there is white smoke coming out of the exaust but no bang any help would be great thanks Andy.
Re: MY E27N WONT START :-(
Posted: Sat Nov 05, 2011 5:50 pm
I am no expert on the E27N but white smoke would indicate un-burnt kerosene/TVO/paraffin to me rather than petrol. Petrol smoke is usually black or it is on my DKN.
Could also be water from a leaking head gasket.
What do the plugs look like when you take them out? Have you tried rubbing a pencil on the electrodes? Have you tried heating them with a blow-lamp and putting them back in hot?
Posted: Sun Nov 06, 2011 4:07 am
by Tim W
if you get smoke then it's burning something so the electrics ok...
could be a lot of oil in the cylinders? clean the plugs and a spot of petrol down the plugs mightwork...
- if you have kerosen/parafin/tvo in the main tank and petrol in the small tank it could be you're tank is holed internally and the tvo is mixing with the straight petrol ....
- try setting up a small seperate tank with just petrol in and going from there
