E27N NOT STARTING
E27N NOT STARTING
HI JUST AN UPDATE DID MY TIMING TODAY AND NOW WE HAVE BANGS IN THE RIGHT PLACE BUT ITS NOT WANTING TO RUN IT FIRES AND THEN STOPS WHICH IS A BIT WEIRD HAS ANYONE ANY IDEAS? THANKS ANDY
Re: E27N NOT STARTING
Firing Order?
1342?
Not positive on the E27N, But from the old Model F's, and N's, the firing order is 1-2-4-3. Ford also used this Firing order this on model T, and A ,and B, also the model C engine, 4 cylinder cars and the line of Ford tractors built over here. 9N though the number series. Dandy Dave!
assuming you've got a good spark on all 4 plugs, it sounds short on fuel , or very weak - are the plugs wet?
- if they are then probably electrical...
if not, check carb and make sure the 2 valves on the back of the manifold work or it will draw in too much air
1947 E27N, some grey ones and a 1953 AJS 350...
