Hi there does any one know the correct grade of oil for the gearbox and diff and quantity's
Ash
Gearbox oil
Gearbox oil
1950 E27N Petrol/TVO
1956 New Major Mark1
Re: Gearbox oil
Hi, my instruction book says: use S.A.E. 90 oil for both, gearbox holds 12.5lts, rear axle 40.9ltrs
Hope this helps,
Chris
Hope this helps,
Chris
Re: Gearbox oil
Thats great thanks for your help is EP90 gear oil ok to use
Re: Gearbox oil
That's what I would use. My understading is SAE90 is specially designed for use as a gear oil. It's not necessarily thicker than 40 or 50 weight but with different additives making it suitable for gear boxes and diffs etc.
Re: Gearbox oil
Hesford,
Do not use EP, HD or GX 90 in the Gear Box and Rear Transmission of your E27N. The additives in these oils can eat the leather seals and pit the bronze bushes, you need to use a GL1 Mineral SAE90.
BarryM
