Fordson p6 oil filter
Canadaford
Post by Canadaford »
hello im new to this forum im currently in the process of rebuilding and restoring a fordson e27n p6 got the whole motor re done new mains, sleeves, re done rods, cast pistons all back to origional the whole tractor is taken appart and put back together i only have one problem the tractor has the vokes oil filter housing on the side and i have no idea what filter goes into it? or does anyone have a brass canister that goes inside the oil filter housing that their not using anymore and willing to sell any help i appriciated thanks alot from Canada
BarryM
Site Expert Team
Site Expert Team
Re: Fordson p6 oil filter
Post by BarryM »
If you can obtain a Fleetguard LF4034 element, then you do not need the brass cage.
Otherwise, you will need the brass cage and a Fleetguard LF599 or a Baldwin P15 element. These last two elements must be used in conjunction with a brass cage.
BarryM
