E27N Weight
BarryT
E27N Weight
Post by BarryT »
I cannot find the answer on the board so can anyone tell me the weight of a standard E27N, I would immagine it to be heavier than the E1A Major which I believe to be 2.25ton.
Regards,
Barry
OGoldsmith
Re: E27N Weight
Post by OGoldsmith »
Fordson E27N should be around 1 3/4 tons. Though my mate rekions there more 2ton like the E1A Major.
Ollie
1940 Fordson Standard N 1948 Fordson Major E27N
CalGG
Re: E27N Weight
Post by CalGG »
From the service information
Ag with Spade lugs 4340 lbs 1968 kg
Land utility 4214 lbs 1911 kg
Row Crop with Spade lugs 4368 lbs 1981 kg With Pneumatics 4062 lbs 1842 kg
Industrial 2ton 13 cwt 3qrs 2770kg with wheel weights and ballast
cheers
brockwood
Re: E27N Weight
Post by brockwood »
interesting to see the difrences power farming 1953 states for aus spec tractors with cast wheeles and i think full water
6775 lb 13x28
7500 lb halftrack
p6 7532 lb on 13x28
7623 for halftrack
crawler 7480
p6 8370
no wonder my truck complains with the halftrack and crawler on thow its pretty weak b
BarryM
Site Expert Team
Site Expert Team
Re: E27N Weight
Post by BarryM »
As quoted by N.I.A.E. Report -
Fordson Major Petrol Kero Rowcrop -
Total weight of tractor on 100% water ballasted 11x36 tyres with three weights per wheel (without fuel and operator, but including oil and cooling water weighbridge figures) 6754lbs.
Weight on Rear Wheels 4741lbs.
Ballast weight on Rear Wheels - water 994lbs.
Wheel weights 688lbs.
BarryM
CalGG
Re: E27N Weight
Post by CalGG »
I did run my E27n up on the scales for the tractor pull at the local fair some 10 or 12 years ago. IIRC she was just over two tons.
I don't run wet wheels, but do have the two pair of iron weights fitted.
Not much or her has rusted away since ;-)
