Head gasket
MH55k
Head gasket
Post by MH55k »
Anyone know where in oz I can get a new head gasket for a e27n ? While on the cylinder head subject does anyone know the tensions for the head bolts as the manual I have for the tractor has no info on tensions
1947 Massey Harris 55
1942 Massey Harris 82
1953 Mcormick Aos6
1946 E27N
CalGG
Re: Head gasket
Post by CalGG »
Can't help with the head gasket, I had to make my own last time I pulled the head. Just fiber (no copper) but it seems to be holding fine. Now one can purchase them from the UK without much trouble.
As far as the head bolts go, I hear that "good and tight" is just about right.
Look at the bolt, put a box end wrench to the head and give a good pull. (Sequentially around the entire head of course).
If it leaks, (straight water at first even if you plan to run coolant) tighten 'em up a bit.
If you break off a bolt. Oops!
Cal
MH55k
Re: Head gasket
Post by MH55k »
Hurrah for the she'll be right method . Looks like I'm gonna have to call the old 20 parts co may as well get some other bits and pieces while I'm at it
1953 Mcormick Aos6
1946 E27N
Re: Head gasket
Post by Dandy Dave »
You can always refer to a bolt size torque chart. Dandy Dave!
MH55k
Re: Head gasket
Post by MH55k »
Did not think of that one thank you dave
1953 Mcormick Aos6
1946 E27N
