gasket
Posted: Sat Jul 20, 2013 6:51 pm
by paulus
Hello,
does someone know what material the valve chamber cover gasket is made of and how thick its should be?
Regards from Holland,
Paul.
Re: gasket
Posted: Sat Jul 20, 2013 7:14 pm
by super6954
The gasket should be cork. if you are making one i would say somewhere around 1/8th to 3/16th of an inch if the plate is true and not bowed / bent :wink: . I made one for mine and its a bit thicker than 1/4 inch. The face surfaces where pitted, and I wanted to make sure it squashed up really well to seal. Plus it was a left over off cut from another job, so it was free :!: and it worked good :) .
Re: gasket
Posted: Mon Jul 22, 2013 7:14 pm
by paulus
Thanks Robert for the advice.
regards from Paul in Holland.
Re: gasket
Posted: Tue Jul 23, 2013 8:32 am
by Emiel
Hello Paul,
We made ours from thick gasket paper. Little fluid gasket and its tight.
Rgds
