Hi I am buying an acreage tractor and I am wondering what the easiest way is to identify the model? (besides serial number)
I am hoping there are differences like lights, seats, or something that is visually different
Looks Like an NAA. Later than the 9N, 2N. 8N. And a little better because it has overhead valves. If the badge on the front says "Golden Jubile" then it is a 1953. I believe the serial numbers are stamped just behind where the starter mounts. Dandy Dave!
You should not have a problem hauling it with a two axle car and equipment trailer and pickup truck even if the tires are loaded. I have moved these on my 7,000# trailor many times. Dandy Dave!
Yup, I can see that out where you folks live. Back here in the eastern US, plots of land are much smaller and these were very common on small 100 acre or less farms. Also commonly used around orchards, and for vegetable farming. Dandy Dave!
