Model N tank problem
Posted: Thu Oct 16, 2008 11:32 am
Message from John, a new member:
Hi Brian, E mailing you viafordsontractorpages forum. My g't grandson has just acquired a N Fordson. The fuel tank was badly corroded and he has been given another in sound condition. Unfortunately the internal baffle has come adrift in the parrafin side of the tank and some creature has also used it for nesting purposes. The only way I can see to rectify this is to remove the end panel by unsoldering the joint then removing the nesting debris and refixing the baffle. Have you come across this problem and do you have a solution or alternative suggestion? Regards John
