Vibrating motor
Paddles
Vibrating motor
Post by Paddles »
Hi, doesn't anyone know how to identify the model of a Fordson major motor diesel from any way other than a number on the motor, There is a serial number but can not find model number, the motor is in my yacht, and need to find out what year and model it is have a workshop manual for the motor but it covers 7 different models, the motor has a problem with vibration, the mechanic has reset the timing and tappets, thanks
super6954
Re: Vibrating motor
Post by super6954 »
if we could have the numbers you got that will help us. The other thing is does the motor have the fuel pump bolted right to the timing case, or is there a visible coupling between the motor and the front of the fuel pump.
Some guys call the later 65 up to 80's industrial motor a major motor on ebay and it isn't . you have Dagenham, Dover, and Dorset series. all 3 are different in some way or another. 4 or 6 cyl will help to as if 6 it would be an industrial or truck 6 cylinder
