I want to send my magnet off for refurb, but am not sure how to take it off. There are 2 small screws on the fwd end of the magneto, can I remove these and withdraw it, or do I need to remove the 4 bolts that hold the magneto housing onto the tractor body, and send the whole lot off?
Any advice will be great.
E27N magneto removal
Ford 2000 - Pre-force
1958 Dexta
Roadless 75
MF35 Industrial
MF135 Industrial
MF135 multipower
MF 165
MF 240
MF 360
MF 20E - Industrial
MF 20B - Industrial
MF 20B - Industrial with 7 gang mower
SAME Solar 60
1958 Dexta
Roadless 75
MF35 Industrial
MF135 Industrial
MF135 multipower
MF 165
MF 240
MF 360
MF 20E - Industrial
MF 20B - Industrial
SAME Solar 60
Re: E27N magneto removal
From what I remember its the four bolts pointing upwards into the mag base, the Mag separates at the coupling, make sure you wire the loose bit of the coupling to the bracket, its the sort of part that tends to go walkabout while you are waiting
Thanks Oehrick, I'll have a look at that tonight.
1958 Dexta
Roadless 75
MF35 Industrial
MF135 Industrial
MF135 multipower
MF 165
MF 240
MF 360
MF 20E - Industrial
MF 20B - Industrial
SAME Solar 60
1958 Dexta
Roadless 75
MF35 Industrial
MF135 Industrial
MF135 multipower
MF 165
MF 240
MF 360
MF 20E - Industrial
MF 20B - Industrial
SAME Solar 60
Dunno if you have a manual for the E27N but one can be downloaded in a variety of formats here
https://archive.org/details/tractors-23 ... tor-Manual
I find the PDF format best, the free document reader downloadable from www.adobe.com is better than the plugin some web browsers use
HTH
HTH
Thanks Oehrick, I sent my magneto off and got a replacement unit. The tractor is now firing up no bother and seems to run a lot sweeter than before - getting a good spark probably helps.
I've got a manual already thanks. The guy I got it from gave me one, but its always handy to have it in pdf too.
1958 Dexta
Roadless 75
MF35 Industrial
MF135 Industrial
MF135 multipower
MF 165
MF 240
MF 360
MF 20E - Industrial
MF 20B - Industrial
SAME Solar 60
1958 Dexta
Roadless 75
MF35 Industrial
MF135 Industrial
MF135 multipower
MF 165
MF 240
MF 360
MF 20E - Industrial
MF 20B - Industrial
SAME Solar 60
Great news
amazing what difference a big juicy spark can make !
