Age & Model info reqd
AndyJB
Post by AndyJB »
Hi-on the battery firewall a previous owner has fixed a plate with SABTVRO 348A184717
the engine number as far as I can make out is ELADOW-6050-G
J3167
the gearbox appears to be BADKN 7007F TI
and the rear axle 47123 but very hard to read so may be wrong
Any advice/info on Tractor's age and model, also if it's likely to have the 'top' filter in the rear axle/differential much appreciated, regards, Andy
SkidRoe
Location: Tetenhall Wood, UK (was Thorndale, Ontario, Canada)
Re: Age & Model info reqd
Post by SkidRoe »
Those numbers sound like ones from a later 1000-series tractor, or maybe a late Super Major.
Can you post a picture of your tractor?
Thanks - SR
Fordsons: 22 F, 36 N, 50 E27N, 60 FPM Past: 60 Dexta, 61 SM
Fords: 78 6700 Turbo, 81 TW30, 89 4610 4x4 w/ Frey ldr, 96 7740 SLE 4x4 Past: 72 4000 w/ Allied 660 ldr, 75 5200, 76 9600
Others: MH 30 & 44, Oliver Super 55, Bobcat 440b & 773
