Front timing cover seal
Hi all.
I am about to replace the timing cover seal on my major. According to the manual I have, it says you have to wheel the front end away, as in side rails, front axle, tombstone etc. Is it possible to remove the timing cover with just the nosecone and rad removed?
Thanks in advance.
Huzey
Thanks in advance.
Huzey
I started off with nothing, and have still got most of it left!
You don't even have to remove the radiator or nose cone. I take the bottom hose off, start the big nut with a long punch and hammer, go underneath with a long soft, punch and drive the pulley off. Take all the bolts out of the timing cover and you can fiddle it out.
Hello Brian and Huzey,
I have to do the same job, but want also renew the seal behind the engine front mounting plate and if neccecery replace that, because some threath hole are bad.
Could this be done without removing the front axle and side bars?
If you need the front plate off, I would take the radiator and front off all in one piece. Jack/block under the clutch housing. undo all the bolts on the front plate mounting to side channels, the four sideplate bolts on either side to the clutch housing and the drag link. Remove the radius rod pin from the sump, as you jack up, the radius rod will drop out and allow you to move the axle forwards. The front axle can then be used to carry everything away.
There are some pictures on the Wiki on the "Henrietta Overhaul" thread that shows how I did it. Front mounting plate gaskets were always a problem on loader tractors so it was a pretty common job. We always did it that way.
Decided to take the rad and nosecone off after all, and as per Brian's instructions, got the timing cover seal done with no problems at all.
And, threw some primer at her ready for a fresh coat of empire blue.
Collecting 4 tyres for her tomorrow, and then draining the back end to replace the pto selector shaft seal and the pto back end seal. Then wheels off and sort the brakes out, get the rims sorted for painting, carry on cleaning up the rest of her for priming before giving her a few coats of empire blue. Starter motor rebuild, panel beat the nosecone, new set of grills, though not orange ones, sort the lights out and the job should be a good 'un!
Really enjoying my week off so far
Huzey
Huzey
Hi Ben.Bensdexta wrote:What did you do in the way of surface prep for painting?
Looking good!
All the best,
I gave it a thorough degrease, and pressure wash off and that was about it. It is not a full blown restoration, just stop the oil leaks, and a blow over and a new set of tyres.
Talking of which;
Collected these this morning, and progress on the major today was replace the pto selector shaft seal and the rear pto seal. That spring and ball detent on the selector was a bit fiddly, but apart from that, all went well.
Huzey
Ready for degreasing and washing off tomorrow, and then a coat of primer before getting some blue on her on friday.
Got to order some brake shoes and then hopefully, once the expanders and adjusters have been freed off, and the drums cleaned up, I will have some working brakes for the first time since owning her!!
Looking forward to getting some blue paint on the old girl!
Huzey
Thanks Henk and Pascal. Of course, taking it apart is the easy bit. It's the putting it back together that always takes the time. If I can get the skid unit in blue and the wheels and tyres sorted out by Sunday, and then it will be back to work on Monday. Then it will be a case of preparing the tinwork and getting that painted next week, while we still have the good weather, hopefuly
Thanks for all the support and interest.
Huzey
Huzey
Huzey,Huzey wrote:I gave it a thorough degrease, and pressure wash off and that was about it. It is not a full blown restoration, just stop the oil leaks, and a blow over and a new set of tyres.
So you paint over any rust, old paint etc with the red oxide, which should be good for a few years at least?
What paints are you using?
Impressive progress, look forward to more pics
All the best,
Yep, thats about it. My thinking behind it is, if it has lasted 54 years in its original paint etc, then a quick degrease and blow over should do well for another few years. I shall give the tinwork a good going over with the wire brush on the grinder followed by wet and dry paper and hope my spraying is up to leaving a good finish without the london marathon on it. (lots of runs ) I am using case new holland red oxide and I think I got the empire blue from either agriline or southern counties tractor spares.So you paint over any rust, old paint etc with the red oxide, which should be good for a few years at least?
Huzey
Oven cleaner has a low concentration of caustic soda (Sodium Hydroxide) - however its a powerful chemical. I'm using a caustic soda gel that is typically used to degrease stone and brick before chemical cleaning. It was left over after I cleaned the stone on the house.
It called Neolith 425 and is much stronger than oven cleaner and being a gel it can be painted on. You have to be very cautious with it - I have a full chemical suit complete with full face/head mask. The first time I used the suit my neigbouring farmers thought that foot and mouth had broken out again!
It dissolves paint down to bare metal in no time - just need to keep it moist in really hot weather while it does its job. One application is all that's needed and after a jetwash it leaves a grease free surface ideal for repainting.
Andy
Andy
Well, got her degreased today. Am using something my other half sells at her company, and it is made from oranges! It is environmentaly friendly and it smells nice too, and worked quite well. It is called citraclean and it is the high strength stuff.
Got her primed quite early so I thought I would give her a coat of blue as well.
Quite pleased overall, but the more I look at it, the more I see I have missed!
Will give her another going over in the morning.
Huzey
Huzey
That is starting to look very nice! I used the same method when I painted mine. I just washed and degreased the tractor thoroughly. It was covered with thick layer of old grease mixed with dust. I had to wash it several times with a pressure washer. I used blue paint-over-rust Hammerite paint as a primer. It remains to be seen how long the paint will stay on.
The front ones are the bull pinion shafts that come out of the dif. These then drive the half shafts through large reduction gears in the transmission case. Not like a Dexta where the half shafts go straight into the dif. gears.
Bull pinion shafts have the brakes on the end. They were put on the long housings to eliminate oil leakage that the E27N suffered with, when the brakes were mounted close to the transmission case.
When seal technology improved, the brakes were remounted close to the transmission case again. The brakes were up rated to discs at the same time. This was in 1962 with the Super Major.
Looking very good Huzey - what type of sprayer are you using? I have a normal compressed air sprayer but I'm toying with the idea of getting an airless sprayer so you get less overspray/wastage but the ones that have Xylene resistant seals tend to be a bit expensive.Huzey wrote: hope my spraying is up to leaving a good finish without the london marathon on it. (lots of runs ) I am using case new holland red oxide and I think I got the empire blue from either agriline or southern counties tractor spares.
Huzey
Andy
