Bought a 57 Major Project & Need info on how Starter wiring should be ran on it?
Nothing connected as of now< Pics of how yours is wired would be Great?
Thanks, Rick
How's your Starter Wired up to Operate?
toomanytoyz
toomanytoyz
Kiwi Kev
Rick
Here is my wiring diagram for my 57 Major.
It has the lever starter, an alternator and uses an aftermarket "spring loaded start" ignition.
You need to use both the lever and the key in the start position for it to work. Disregard the electric fuel pump.
Hope this helps
Kiwi Kev
Hope this helps
Kiwi Kev
"Classic Contracting"
International 784 4WD
& looking at another tractor!
