hi
i just bought a fordson major and have few questions
-schould i refit de engine with new bearings, the motor still runs great but can i wait untill it stops running.
-i heard the breakes and fireplate are made of asbestos. some people tell me i should let it remove by a special company because one fibre can kill you. and others thell me its safe if i wear gloves and a dust mask. on the internet i read that asbestos can stick on clothes and contaminate others
what should i do?
major engine & asbestos
In answer to your question about the bearings I would ask, how old you are? Because if you are going to wait until the engine stops running you may be very old when that happens.
If your tractor is running, with no major oil leaks, smoke or starting problems, do nothing and enjoy it.
If you want to restore it and paint it up like new with cost being no restraint, then strip it down and rebuild it.
But remember, your Major is a tool to work with and like all tools, if you do not use it, it will deteriorate no matter how nice it looks. (IMHO).
The cluch disk linings also are made of asbestos. Also, some gaskets are lined with asbestos especially exhaust and manifold where the heat is great. Don't remove them with anything that turns then to dust. Just scrape them carefully. When ever I work on brakes or clutches, on any make, I use a high pressure washer and wash the dust away. Dandy Dave!
Just wonder sometimes how I have managed to stay alive!
We cleaned everything down with an airline when doing brakes and clutches, no one told us about asbestos.
If you don't cut or drill it and wash the clutch housing and brake parts, you have no problems. Keeping the firewall painted seals the problems.
