Raised pto
Gman
Raised pto
Post by Gman »
Hello to all. I power washed the raised pto on the parts Major I have and noticed the retainer seems to cover the upper right bolt slightly. I understand this bolt should not be removed from the raised pto to keep it all together. Do I have to remove the retainer in order to remove the raised pto from the rear end housing? Thanks for any advice.
Gman: 1959 Power Major
JC
Post by JC »
Gman,
On mine, its not actually covered, but it's so close that you can't get a socket on it. A good quality (like Snap-On or Mac) open end wrench should loosen it. A cheap one (like Harbor Freight) will spread and round off the bolt head.
Gman
Post by Gman »
Thanks JC, I took it off yesterday. A lot of short turns with the open end wrench but it is on the bench. Thanks again.
