The shifter on my Power Major will spin around so I'm going to try and put the shifter from the Major on her. This is the shifter I took off the Major, sitting beside the raised pto, and a shot of inside where it connects: The shifter looks to be in good: Hopefull this will fit although the bend in the shifter is different from the one on my Power Major.
The problem with the lever turning is a little pin in the side of the housing has failed. Easy fix if you take the lever out, drive out the pin and make a new one.
Thanks Brian. When I took the one off of the Major I noticed a pin on left side of shifter housing. I looked at the one on my Power Major and it is sticking out of the housing maybe 1/8" or slightly more. If this is the pin you mention can I just tap it back into the housing to keep it from spinning around?
