Brian,
This afternoon I took the valve casting off and stripped apart the valve.
It all looks ok and seens to be a good fit, but I thought I had better try and put some pressure in it with the grease gun to check.
I filled the cavity with oil first before blanking it off
Without doubt a little oil is passing the end of the valve, more so if you rotate the valve
It passes with the valve in or out. I don't know how much pressure the grease gun is putting in there but I imagine it is not anywhere near as much as when the plough is on the back?
Theses pictures show where the oil ends up going. It ends up straight back in the area above the cylinder.
But, in the video when I pulled the valve out the arms stopped dropping once there was no oil feed to the cylinder, so I would guess that the oil that is passing this valve is not realy enough to make a noticable drop in the arms.
I did wonder about temporarily blocking the hole to proove if this small leak is having any effect, but I presume this hole may pass oil back from the flow valve as well?, as the hole goes at right angles through the casting.
I'm also trying to figure out why, in the last video, it didn't always make the pressure relief valve work until I turned the valve. I would be suprised if it could pass that much oil.
I could do with one of those endoscopes to look inside when it's running!
