Hi Gents, I'm helping Mark from NZ out with a raised PTO off my spare PM.
I've got the raised box off but the shaft won't budge.
The shaft appears to identical to my normal PM PTO except for the tread for the crown nut that holds the gear on.
Any advice would be greatly appriciate.
Thanks Jason
Removing PTO shaft advice.
Re: Removing PTO shaft advice.
Jason, I believe it just slides out of there.
Pat
Pat
Thanks for the reply.
I've tried again, the only two things that I can see might be causing it to be stuck is.
1.0 the PTO is stuck in gear. If so how can I disingauge the PTO leaver to free the PTO up. (When it was disengauged I still could not release the shaft.)
Or
2.0 the Bearinghousing is stuck/ jammed.
Jason
Or
Jason
