Rear Axle bearing removal
Fixersteve
Right then, Last night i lifted the top cover off my Super so that i can remove the rear half shafts to renew the outer axle seal. How the flip am I suppose to pull the outer bearing off the shaft?? any tricks??
Re: Rear Axle bearing removal
hello i don;t know if you have a hydraulic press ?
http://s1232.photobucket.com/albums/ff3 ... C01064.jpg
the outer bearing ring you can get out by using a big puller, and heating the ring
http://s1232.photobucket.com/albums/ff3 ... C01068.jpg
ofcourse there are many ways to do it
If the tractor has been standing the seal(s) may have hardened.
Mine did and leaked. I then used the tractor to plough 3 acres and the problen disappeared. Guess the oil got hot and the seals softened. No further problems over the next five years.
Worth a try even if you drive it round for 4-5 hours.
Good luck
Good luck
AdrianNPMajor
AdrianNPMajor
Oops. Just re-read the question and I haven't answered it!
Once I had my half shafts out, I asked a local engineering firm to use a press to get the bearings off. Sorry I can't be more helpful.
Best
Adrian
Best
Adrian
The tinwork is spiked into a groove in a number of places and is easy to prise out, there is no need for jacks or big hammers.
Kiwi Kev
This was the original question, not how to get the seal offFixersteve wrote: How the flip am I suppose to pull the outer bearing off the shaft?? any tricks??
"Classic Contracting"
International 784 4WD
& looking at another tractor!
Kiwi Kev
Adrian
AdrianNPMajor
I had already apologised.
Fixersteve
Cheers Chaps! I have got a hydraulic press so will have a go with that today.
Kiwi Kev
Yes, you had,AdrianNPMajor wrote:I had already apologised.
and you also provided the approiate action for removing the bearing.
Look forward to photos fixersteve
Kiwi Kev
here a topic with picture of original bearing puller
http://www.fordsontractorpages.nl/phpbb ... f=9&t=2987
Fixersteve
Cheers chaps! Have got the bearings off this afternoon. Will upload some
Pictures later.
Pictures later.
