I have one lift arm off and have taken the lid off the back end now I'm stuck
Cross lift shaft removal
major m
Help
need to replace lift arms and cross shaft but how do I get the shaft out?
major m
Re: Cross lift shaft removal
Sorry forgot to say I'm working on a 61 super major
You need to take the lift off as the shaft only comes out one way and there are washers that will drop down so the new shaft will not go back. The centre housing may also be rusted onto the cross shaft and may need heat and a lot of force to free up.
major m
Thanks Brian, can you tell me which way the shaft needs to come out as the off side lift arm is seized on.
I should mention I'm changing the shaft and lift arms as agriline replacement lift arms won't fit on original
Cross shafts due to them being made with a locating key way.
Cross shaft goes out towards the Quadrant. The bushes on that side will come out too as the centre spline is larger than the outer bushes. That is why it will only go one way as the centre spline will not go through the washer on the other side.
Supers also have a keyed spline in the lift arms and in the centre housing. I suppose the "Land of Nearly Right" has put it in a different place or made it a different size. I suppose it all helps to increase profits!
major m
Managed to get the other lift off but no luck with the shaft. I've heated it,beaten it,swore at,it not a millimetre of movement
Anyone got any ideas ????
Take off the lift cover, then you can heat the the arm for the hydraulic
Fordson for life...
major m
Have the cover off and have heated and banged and cursed but to no avale
Himajor m wrote:Have the cover off and have heated and banged and cursed but to no avale![]()
I had one here I never did get apart just ended up putting a spare top on
I did see one once was so worn guys drilled a hole right through the center bracket and shaft, then put a bolt in to lock it back to the shaft
My suggestion would be take it to a responsible machine shop and get them to try pressing it out
Without breaking the housing
major m
Thanks Robert
I had thought in desperation to try cutting the shaft either side of the push rod removing the centre piece so I can get to it easier and try drifting it out. Is that possible or is the shaft hardened?
The shaft is hardened and would be quite a job to cut as you do not have a lot of room. The other course of action would be to split the centre housing but that then leads to more expense. I take it you have tried around for a s/h lift arm?
Another nasty thought! If the splines are wrong for the lift arms the new shaft splines may also be wrong for the centre housing.
major m
The reason for changing the shaft is that the spline was nearly non existent through rust which probably caused the lift arm to spin on the splines. Looks like more expense
I'll try an engineers shop with a press I think
Hi major m
I could not get my cross shaft out no matter how much heat or pressing I applied.
I cut mine into three, using a powered, hand held reciprocating saw, through the removed oil filler housing.
The centre (the rusted bits ) dropped out and the shaft ends were then easy to remove.
Once the centre was out in the open it was very much easier to work on the shaft/radius arm and free them.
The shaft on my Fordson was the square type and was not hardened but I have no knowledge of the splined type.
Being the square type it was very easy to make a new one.
The reason I wanted the shaft out was to be able to renew the bearings and bushes that support it.
Dennis
Dennis
major m
Had to split the ram arm off the lift shaft but its out.. All I need now is a new ram arm.
A quick question, are there two bushes either side on the shaft with an spacer I between or is it three bushes can anyone
let me know.
Many thanks Mark
Two bushes and a spacer with a square "O" ring on the outside.
major m
Many thanks Brian, not sure what you mean by square o ring,only have a thrust washer next to ram arm and locking tabs on the ends of the shaft
I think brian means square oring for square shaft
i dont think you can fit it on yours spline
Fordson for life...
AdrianNPMajor
Haven't done this job before so all new to me and learning a lot. Have to admire Mark's terrier-attached-to bottom-of-trouser-leg tenacity! It's clear that this job, tricky as it is, is not going to beat him.
Mind you ..........
Best
Adrian
Mind you ..........
Best
Adrian
No, not the same as the Major but the "O" ring could have been a "Service Modification" as Fords called it. It was fitted to the Ford 5000 as standard from 1964.
major m
All fresh oil in both gearbox and rear end lets hope it works
major m
AdrianNPMajor wrote:Haven't done this job before so all new to me and learning a lot. Have to admire Mark's terrier-attached-to bottom-of-trouser-leg tenacity! It's clear that this job, tricky as it is, is not going to beat him.![]()
Mind you ..........
Best
Adrian
I'm gonna have a go at pics tomorrow with the help of the wife
AdrianNPMajor
Best
Adrian
