power major charging problems
Hello whilst running my power major there is no charge I read some posts and cleaned the dynamo inside and checked to see if it would spin like a motor. Which it does well. Then I cleaned the regulator inside. The points were green and dirty. But now when I connect the battery it sparks like the terminals are the wrong way round. Is there anything I could of adjusted in the regulator?
Re: power major charging problems
Bet you have reversed the polarity of the dynamo with your test. Fit the dynamo to the tractor but do not connect the wires. Then run a wire from your output terminal on the battery to the small terminal on the dynamo and just touch it a couple of times. It may spark but then its job done. Connect up all the wires and check.
It was all ok when I tryed it after playing with the dynamo it all started when i cleaned the regulator. I think its something i touched in there.
my parts dealer told me, regulators are changed completely when not in order, but I repaired mine. Look here
http://www.worldphaco.net/uploads/REPAI ... _RB106.pdf and here
http://www.voc.uk.com/net/docs/16/16-357-22.pdf
It's a bit tricky to adjust, but seems possible. Search Google for "Lucas RB108 voltage adjust". These regulators are in a lot of british vehicles.
It's impossible to see the contacts working, they are too fast for your eyes. You need a voltmeter to control the voltages.
Peter
Peter
1963 Super Major
