Get Fordson Super Major faster
Hello,
I have a Fordson Super Major and I want to know is it possible to make the Gear Unit faster?
Kind regards
Kind regards
Re: Get Fordson Super Major faster
Faster...???
Mine goes fast enough that it scares me now in high going down the road. Dandy Dave!
bigger wheels.
BearCreek Majors
do a little searching here, there were two different ring and pinion ratios available for the Supers.
Or you could put a 350 Cheby in it......and then you could drive it to Mars.....or cross the English channel.....or jump the snake river!!!!
Pat
(No I am not on crack)
Pat
This conversion is rather speedy... http://www.youtube.com/watch?v=OQvikmrxZQM Dandy Dave!
And another... http://www.youtube.com/watch?v=rnnyB639q7k Dandy Dave!
richard the wrecker
Nearly as speedy as this.
http://youtu.be/fAfshuIMA9w
WD9 with Perkins P6 with rotary pump & turbo =33MPH
Hi nice speed on that "red thing" at least Dave stuck with the blue theme of the forumrichard the wrecker wrote:Nearly as speedy as this.
WD9 with Perkins P6 with rotary pump & turbo =33MPH![]()
I got a red thing here built on a Belarus MTZ 50, fitted with a perkins V8 turbo reving to 2500 rpm and over sized wheels, I built for pulling in the U.K before moving here when we were dealers. Bet it would tow that international down the road faster than that
Mines not how straight it goes or stopping it's how much nerve you got to keep pulling back the loud lever in top gear
Hi it depends on what your trying to achieve if you want to gear it up a bit to say cruise at 15 mph at reduced revs fair enough and a standard tractor with well maintained steering no probs however the temptation is always there to open it up. here I believe the limit is 25 mph non sprung front axel 2 wheel brakes 35 sprung 4 wheel brakes and 50 if hydrostatic steering I have seen pictures of a 6cl major I think set up for chaser bin work it had a truck front axle with lengthwise springs and brakes .I have no personal experience of upping the gearing on a super though iv studied the problem as I run e27s a super appears to be basically a e27 special high top with a selectable underdrive in front the trouble is to do it with out ruining the tractor for work I believe Howard made overdrive sandwich boxes like the under drive for trenchers but you would never find one I have seen altered tractors that weren’t to bad iv actually driven tail end Charlie http://www.tailendcharliethetractor.org ... 01957.html which had both the diff and bull gears raised its very high geared another is a lanz bulldog near hear with a gear recut to give 30 k told me it took three goes to get it to work tows a living van one trip to the national rally was 7,000 k that’s not a typo however the favoured thing in days gone by was a powered trailer to push you if you think about it direct drive off the pto is only idle in top on what ever old truck axle you use for it so about 25 mph . The other thing I have seen is a power leg it consists of a right angle drive off an inter baler I think mounted on a linkage headstock with a chain drive down to twin 13 inch wheels on the centreline so the tractor stays balanced the linkage it tied down and he applies down pressure by pushing out the hydraulic top link drives it everywhere at up to I believe 40 mph b
super6954 wrote: Hi nice speed on that "red thing" at least Dave stuck with the blue theme of the forum. although the purists that visit here will decide his punishment, later for posting as they call them murdered Majors
Put me in the chair that Dunks me in the water tank... Oh wait, let me get my speedo on..
Hello,
thank you for the answers.
Something around 20 mph would be fast enough.
Is it possible to do this with the original 4 cly engine?
Kind regards
Kind regards
AdrianNPMajor
In my experience and opinion the Major is not really designed for road work. The chunky transmission is epic in field operations, but on the road, as a vehicle for going from A to B, it just doesn't cut it. How could it? Changing the gearing to be able to eat up tarmac more quickly would therefore not be a wise objective. Whenever I trundle along the road, the Major feels out of its element as the road-going vehicles whiz past. But when I arrive at my destination and pull into a field, it's a different matter. The Major is suddenly transformed and is completely at home.
Best, Adrian.
Best, Adrian.
no matter where your going in life youll not get there any
quicker no mater how fast you try to go ,take it easy and enjoy life
your major is an old age pensinor let him take his time
