I reuse an old thread, because the heading says it all.
I think my coupling is different from the one above.
Here it is:
outer diameter is about 35mm,
inner (the part that is pressed inside is about 15mm
and the pipe behind is 13mm
Is this this the male part? Is this the 1/2" BSP version (the bigger one)? The thread was 13/inch, if I got it right.
I saw an adaptor at sparex (
http://v2.ir.sparex.com/ItemDetails/Ite ... mber=13338, will it fit my coupling?
Is there any sealing between the couplings?
Peter
