Lift pump
Dazo1960
Lift pump
Post by Dazo1960 »
I can not get the lift pump to fill to the top only fills 3/4 any ideas regards Darryl
Pavel
Re: Lift pump
Post by Pavel »
Had that problem myself. Apparently there are two different pumps with different flange sizes -- one with a glass dome and one with only a metal cover. I obtained a glass domed one and had to make an aluminium plate to cover the extra sized 'hole'. Works well.
Pavel
Re: Lift pump
Should be OK, they do run like that sometimes. As long as you are getting a full flow of fuel down the pipe don't worry.
Dazo1960
Re: Lift pump
Post by Dazo1960 »
Thank you I was told it should be full regards Darryl
oehrick
Re: Lift pump
Post by oehrick »
Just a thought, has yours got the fine circular gauze filter fitted (which plugs in the centre of the pump under the dome) ??
Dazo1960
Re: Lift pump
Post by Dazo1960 »
Yes I believe it has regards Darryl
