What does the pull up knob behind the hand brake do?
It pulls up and then turns so as not to drop back down again. I have no idea
Pull up lever behind hand brake??
Re: Pull up lever behind hand brake??
It is a lock for the foot brakes. Pull it up and turn it then push the foot brakes down, they will stay down until you release the handle. Some tractors were not equipped with the transmission hand brake.
Works perfectly. I use it all the time.
Grand
Cheers chaps
Cheers chaps
And a lot less damage when you forgot to release it.
Transmission breake works great.but can create a lot of work in the transmission part of the tractor.
