Looking at the play on my crosshaft, there is like 2mm play on it. There are brass bushes sold, but also steel ones. Which one to choose and why?
Isn't it better/cheaper to get a new shaft then, I don't have access to such a big turning machine? Will the old arms fit on the new shaft?oehrick wrote:That's a bit corroded, if the welding doesn't work out go to someone who refurbishes big hydraulic cylinders you could probably get it metal sprayed cheaper with less chance of distortion, then they can turn it down to the bush sizes you have. Haven't got access to the parts drawings/list as its on my dead laptop, have a look as it probably shows if 2 or 4 bushes needed (Fordson.se ? someone will know where it is posted)
I'm busy trying to release the yokes on the lift rods from the cylindrical bits inside, one down, one to go so far, then I can get the lower links down far enough for the tines of my 'new' Fergie buckrake to touch the ground, thus allowing timber to be picked up rather than manhandling
Good question Mathias, a new shaft made to the correct tolerances should fit, are new shafts made that well ?? I don't knowmathias1 wrote:Isn't it better/cheaper to get a new shaft then, I don't have access to such a big turning machine? Will the old arms fit on the new shaft?
I'm currently trying to get off the last arm, it behave as a bitch
