I had to change a bearing in the brake shaft of my Super. As I had to get the big gear out for that I changed the outer wheel bearing and sealings and resealed the whole axle. One spot less for marking my territory
Question: How much play is needed for the axle? I marked all positions of nut, gear and shaft, but that was much to loose after refitting. My workshop manual tells me something about 40-45 inch-lbs, which converts to about 5Nm as a torque for rotating the axle? Maybe I understand it wrong, but only the felt seal in the axles makes more torque.
Actually I have the gear (and nut) installed with very little (but not zero) play, as there may be some movement needed if things become warm.
Peter (made interesing findings in the oil with a magnet
