Starter barely turns
Re: Starter barely turns
They can get very worn if not adjusted properly, and then changing the bendix is only a half repair as the ring gear is also badly worn, we did that on Billy ages ago and this is what came out:
He still has trouble as the switch wasn't adjusted until much later (the starter had gone to get the commutator cleaned among other things and came back apparently ready for fitting), this meant that early switching happened quite a lot, meaning more wear to the ring gear and a pinion that probably looks more like the old one than a new one. Anyone not used to it will still get into trouble as it needs a rapid movement to get the gears engaged before the starter begins to turn, to spite the solenoid having connected already. This might be the way forward for now for Hyacinth as well.
Very interesting Sandy. I'm thinking this only happens if I engage starter too slow. Then it grinds, then I slowly and carefully try again with same results. I will be sure to move the starter lever quickly from now on. Sounds like Billy and Hyacinth may have the same ailment.
When we first got her the wires were clipped off of the switch. I'm going to guess the previous owner had the issue and bypassed it by using a toggle switch.
leeroy wrote:
Tue Nov 22, 2022 11:33 am
I think that's very likely, Billy's previous owner (who also had the house) used to bump start him on the slope under the pine tree, never using the starter unless he absolutely needed to.
You can also see how different everything was back then.
npaisnel
Post by npaisnel »
I have posted my own question about starters, but if any of you have e-mail notifications to replies turned on, I might get direct to someone that knows straight off! ( yea a bit cheeky I know )
A standard Dexta starter motor… will it spin in correct direction no matter if it is connected positive or negative earth?
Just been given a 58 Dexta wired negative earth… yet told it always was like that as long as last owner had it.
Someone locally tells me they are ‘shunt wired ‘ motors and always spin the same way regardless of polarity.
Any one know if this is correct ?
If any one finds any of my pictures of interest, please do right click and Save Them to your computer as soon as possible.
I host my pictures on my own server and since this site does not save images, they may not always be available,
