does anyone know how i can get a tacho drive unit onto a ford 380 d series engine, i cannot see anywhere obvious it can connect to not sure if it is even possible,
thanks brett
tacho on 6 cylinder
My D series truck has the 380 CID engine. The tacho on my truck is is electric, not mechanical like the 590E engines. From memory the pick up unit bolts into the engine block and is driven by the oil pump. Its located in a bulge half way down the right side of the block.
Steve
Steve
Kav
Hi Super6 - From memory, there used to be a tacho drive adaptor which slides down into the block to connect to the oil pump very similarly to a distributor on a petrol engine. You may be able to machine up one out of an old distributor. I think there used to be a petrol engine in a truck which had a very similar looking block. Other members may be able to add more about this. Best regards -
Michael.
Michael.
