Following on from my post on my jcb.
After getting one of my supers in to work topping a field, the left brake has started to stick on. This had been a problem with my other super and always seems to be the leftside.
I had the linings replaced and cleaned it all up about 5years ago.
I will strip out again, as the tractor has not done anything, untill very recently. Lack of use has not helped.
I am going to replace the actuator return springs and the 6 ball bearings this time. I have sourced a supplier for both. I won't be going to the tractor for a while and want to order the ball bearings in time for my next visit.
To get to the point, what size are the ball bearings please?
super brakes
mark white
super brakes
MARK WHITE, WESTBURY
