And another update;
Right, the oil in the rear end and gearbox Was boiled Linseed(!). Don't ask me why. all leaks had set like glazing or icing on a cake, and gummed up the works as well.
Got most of it cleaned out, and a new PTO seal fitted, washed Hyd. filter/ screen and such, plus magnets and put all back.
re-fitted Hyd. cylinder and piston and valve chest.
Re-filled with new Real tractor oil!
PTO clutch still stuck (no wonder with this gluey oil leaking into the clutch from gearbox) Ran it around the yard a bit, then stopped it and end engaged the PTO.
Ran fine, then tried the lift arms. Nothing doing.............Then, oil running down the back tyre and wheel!
Yes, it had been set up with hydraulics for attachments, and me being used to the Super with the shut -off valve, this one is different and as my hose was open on the hyd. control, I was dumping my fresh oil on the ground.
Fitted a bung in the line and Now the hydraulics work like they should, for the arms that is. Lift and drop beautifully and stay where set when the tractor is stopped.
Next job is split to clean out the clutch and fit new oil seals on cross shaft & front of gearbox. Might give it a bit of work first, to see if the PTO clutch will un-gum. Brush mower or something.
Question;
The hydraulic control has a hole for a cottar pin where the lift lever operates, Is this to keep the lever in the high position when using external hydraulics?
My book might say, but I can't find it at present!
Richard.
