My first post!
I Have a power major which I'm restoring she starts on the button and runs no problem but puffs white smoke and when I throttle her up she pours out a mixture of white/black smoke any ideas?
I've re-timed the pump @ 23deg, had the injectors overhauled and all clean filters and bowl.
I'm miffed and hoping someone can offer me some new ideas.
Thanks all.
Power Major White Smoke
fordsonstreet
How about water in the radiator? Does it go down? White smoke can be an indication of a head gasket failure. This was common on Power Majors especialy if they still have the flat topped liners fitted and not the spigited ones.
fordsonstreet
OK. It might be that you need to get it working really hard for a while. It could be that you are just doing light work and what you are getting is oil smoke.
Another thing to try which is quite easy, take the air cleaner hose off at the manifold and see what happens to the smoke. Do not rev her too hard as the engine will rev a lot higher with the air hose off.
fordsonstreet
fordsonstreet
