So, today I was to meet a tractor mechanic. Said tractor mechanic flaked, but I did call him on the phone. I'm glad he didn't come as he I determined that it was the same mechanic that couldn't determine for the last owner that it wouldn't stay running because the aftermarket electric lift pump wasn't working. I personally figured that out and replaced it, and now it runs.
But, when it runs, it is smoking like crazy. Thick gray smoke. Not "steamy", but more like unburnt fuel.
I thought the timing for the injector pump may be off, but this wasn't the case. It's dead on at 23. So much for an easy fix.
I checked the engine oil for water, none. It's just super black. I think it could be the original oil
Big difference in compression between lever down and lever up so it's not totally gone.
It does like a shot of starting fluid to get started though.
So, what next oh wizards of the Fordson? I was thinking of yanking the injectors and taking them to a shop, but thought I should find out if there are other things I should check before that (and am willing to accept I could be barking up the wrong tree with the injectors.)
Thanks in advance!
