First, and most importantly, the last time I mowed, my tractor started spewing motor oil on the left side. I traced the problem to a broken oil line, which is made from copper.
I haven't been able to find another line like it at the local auto repair shops. One man suggested using a compression fitting to try to patch the current line. He also said that even if he had a similar line, the fittings on the end of my line were "strange" and he wasn't sure how I would transplant those onto the new line.
I'd appreciate any help, opinions, musings, stories, jokes, or even jeers.
Here is the beast:
Here is the 2 ends of the broken line:
One end connects here, at the front of the tractor:
And the other end connects here, just above the starter lever:
