my np major has lift and lower problems, having asked on this forum before i was told to check unload valve. i lifted top cover and found threaded plug for unload valve, i have tried all sorts but plug will not come out.
with a bolt threaded in and a socket with another nut on top, it will not budge and starts to strip threads in plug.
any idea how to solve this i am losing patients
more unload valve problems
I have never seen one that tight, They are colour coded to the cylinder so someone must have crammed in an oversized plug.
The special Churchill tool for getting them out was similar to what you have. A slide hammer might work but you do not get the pull on it that you are getting. Perhaps a spot of weld on the stud in the plug, let it cool then try again. Or a little heat to just warm the ram cylinder with the force on the drawing tool.
Grandmother and eggs time
Are you sure the plug fits inside the socket you are using?
Go carefully. You may have great difficulty to get replacement items.
The plug is like a cotton reel. Where it reduces in the middle there will be a drop of paint. You should have drops of paint on the control valve and on the ram cylinder itself in the areas of the valves. Each part is very precise in its measurements and must be handled carefully as any scratching, even by using fine wet and dry paper to clean things up, will terminally damage the parts.
Dom,
Olde English saying: "Teaching your grandmother to suck eggs" means telling someone something that they possibly already know. Sometimes, when you don't know someone it can be embarrassing.
