Gearbox & Transmission Brake
Posted: Sun Oct 04, 2009 8:00 pm
Hello . This is my first post on what is am sure will be a most helpful site. Although I do not own a Fordson directly my local villagehall and recreation ground committee ,of which I have been a member since 1982, does. I bought the tractor on their behalf back in 1984. Tractor No 1415835 with an engine casting code of A18A and a gearbox code of A24A. (Jan 1957) have not been able to locate the rear axle code as yet. Since purchased she has been very lightly used and garaged. Apart from a new dynamo and servicing the tractor is as we got her. She starts on the button and runs well and apart from the brakes which need abit of attention the tractor was fine. However recently she was driven by an inexperinced user who either left the transmission brake on or for some reason it stuck on. I was called in after the gearbox jammed with the tractor in the middle of the field.
I removed the clutch pivot plate from the side of the gearbox and could see the damage.The rotating plates had welded themselves to the stationary ones and the pressure had been enough to shear off the two pins that locate the stationary plates. These had then revolved and become enmeshed with one of the gears. With a bit of keyhole surgery I was able to remove the remains of the transmission brake and recover the pins from the botton of the gearbox. This freed up the gearbox.I removed the reverse idler gear and was able to drive the tractor back to its garage.
From what I can see there is no other major damage to the gearbox
I realise that I will have to split the tractor and remove the gearbox to sort things out but my immediate questions are :
Are the two pins just an interference fit in the casing and will it be possible to drill out the bits that are left in the casing without stripping the gearbox down completely, and is is possible and safe to split the tractor using a fixed jack and a trolley jack in the absence of a proper splitting rail
Sorry for the the long post but any help /guidance would be welcome.
