Anyone have an image showing where the valve stem seals fit in the assembly? This is for my '59 Fordson Power Major.
I checked the manual online here, my I&T manual, and some pictures I took prior to disassembling. The pictures are no help, and the diagrams in the manuals don't show the seals.
I seem to recall them being around the valve stem, sitting on the valve guide. But, they aren't really mating with anything. I thought "great, these are too big" and grabbed the old ones for comparison and they are the exact same size (more wore through the center hole and a lot "firmer" though.)
Thanks in advance!
Tim
Valve Stem Seals
LazyTRanch
LazyTRanch
Thanks so much! I was expecting them to "snug" onto something so it was confusing me (which isn't too hard at near midnight my time... so maybe I should save working with the valve spring compressor until after some sleep.)Brian wrote:Seals just push over the valve stem and go up and down with the valve. They should be like a mushroom and direct the oil away from the guide rather than seal it.
Tim
