Here's another daft question:
I was just reading the New Major and Super Major owner's manuals (english versions). In both of them the starting procedure under "extreme cold conditions" is to turn the engine by hand using the decompressor and engaging the excess fuel device.
I started to wonder what are these conditions? I assume that the instructions are written in a British point of view. I'm sure that here in Finland and other colder climate areas the term "extreme cold" means quite something else. So what is the correct temperature when one should start using the excess fuel button? Is there any harm in using it in warmer weather?
Timo
Starting in "extreme cold conditions"
There is no problem about using the excess fuel button in any conditions. It just allows the rack in the pump a little more movement than normal to give her a little more fuel.
We do not have extreme cold over here but from experience, even in the worst winters we had during the 1950's and 1960's most Majors would start with just the button if kept out of the direct cold. In fact a lot of farms kept an old Major to tow start more modern tractors in those conditions.
Does it even get cold, over your side of the country? :-D
I always use the excess fuel button, as standard procedure (let's forget about what I used to do with the decompression lever - I won't do that again..). So far our tractor has started well whatever the temperature, although I have to say I didn't try it during that terrible winter many years ago when it was -52C one morning...
I've never quite understood why these engines start so easily, when everything else needs glow plugs and block heaters?
Brian wrote:There is no problem about using the excess fuel button in any conditions. It just allows the rack in the pump a little more movement than normal to give her a little more fuel.
Roel
Kiwi Kev
Roel
It's a great feeling when the ole girl starts so easily, (and you think to yourself "thats my girl"), but as you say, its even better when the more modern ones won't start so easily.
Not that it gets cold here, but some tractors just start so easily.
Kiwi Kev
Kiwi Kev
"Classic Contracting"
International 784 4WD
& looking at another tractor!
Re: Does it even get cold, over your side of the country? :-
As far as my little knowledge goes it is a matter of size of the combustion chamber. Smaller= more compression=more heating of the fuel/air mixture= easier starting, but also louder running. An increased size of the combustion chamber means smoother running of the engine (that's why the early car diesels were not direct injected) but will also require glow plugs or other aids to get it running at low temperatures. Also, when these engines wear and compression gasses leak between cilinder liner and piston rings, starting problems will occur also at higher temperatures. I recall when I was young and we had a tractor fitted with new piston rings and the cilinders honed; we never had to use the glow plugs anymore.John-Paul wrote:I always use the excess fuel button, as standard procedure (let's forget about what I used to do with the decompression lever - I won't do that again..). So far our tractor has started well whatever the temperature, although I have to say I didn't try it during that terrible winter many years ago when it was -52C one morning...
My conclusion is that our blue machines are "excellent by simplicity".
John-Paul: if you don't mind I hope it gets -52 or close this winter where you live, so you can inform us about the outcome....
Interesting subject; I just doubled my number of posts tonight (to 4).....
Roel
