Anyone help me out ?
Hydraulic filter
Hydraulic filter
I bought a filter but have no clue where it goes.
There is only the washable filter underneath the pump. You get at it from under the rear axle. There is a plate held on with four bolts which has the drain plug in the centre.
Hello Ian,
When I remember correctly you have a standard New Major.
The picture you show is from the Super Major, which has a totally different hydraulic set-up and a return filter.
Your tractor only has the suction filter as Brian describes.
