stuck Major hand brake
Ben 26
Post by Ben 26 »
Is there a quick way to free off the hand brake plates my neighbours got one that's jammed up
Ben,
There is no easy way. You can try going in through the gear selector plate and, with a long chisel/bar try forcing them apart, but the only real way is to split at the clutch and draw the gearbox out after dropping off the PTO.
Ben 26
Post by Ben 26 »
I thought that was the case I may suggest going through the selector plate as it's got to be moved and we were going to drag it with his jcb and get parked up by his workshop
