stuck Major hand brake
Posted: Fri Jan 01, 2010 2:37 pm
by Ben 26
Is there a quick way to free off the hand brake plates my neighbours got one that's jammed up
Posted: Sat Jan 02, 2010 12:20 am
Ben,
There is no easy way. You can try going in through the gear selector plate and, with a long chisel/bar try forcing them apart, but the only real way is to split at the clutch and draw the gearbox out after dropping off the PTO.
Posted: Sat Jan 02, 2010 10:28 am
by Ben 26
I thought that was the case I may suggest going through the selector plate as it's got to be moved and we were going to drag it with his jcb and get parked up by his workshop
