back to work on the county
Re: back to work on the county
Yes, Simply Beautiful. . Dandy Dave!
Thanks guys!
Adrian, In this cold weather you can tell that it’s turning extra gears when you let out the clutch, in the summer it’s not noticeable, and surprisingly almost none of the 4X4 bouncing and grabbing while turning. But I would have to say that it is a little lacking on the hp with the amount of traction it has, thus the Super Six is quite an improvement. By the mid 60’s the majors were getting beat out in the hp market by the other guys over here in the US, they were consider more of an good economical tractor than a brute workhorse. That said, even if they would have left the factory with 150hp, someone would have put four tires on the back, a couple tons of weight, pulling a 5 bottom plow and complaining that it didn’t have enough power.
If you look closely at the exhaust pipe you can see that my pretty stainless pipe is brown, that’s from plowing last spring with 3-16’s, she pulls it just fine but we were burning the carbon out of her.
Pat
Pat
I love the North American colour scheme. Prefer it to the European colours for the NP Super.
Wow! She's a beauty!! Looks like you need a blade on the front of it to push snow with Pat. Good luck with getting the Doe.
Mark
Mark
See ya
Mark
Mark
