Super Major thread in engine block
Roadless63
I have a threaded hole behind the injector pump which throws a bit of oil out, therefore I presume it must go through into the crank case, for now I have it bunged up with a rubber bung, and fortunately there is not too much crank case pressure so it hasn't blown out yet....however it would be nice to source the correct bung. The tractor has a minimec pump, and the hole is directly behind it, anyone know what blocks it off? I guess it would be a machine screw, UNC thread? Any help appreciated, if anyone has got one even better! Thanks, Ed
That is a standard machine screw with a little fibre washer. It is the oil feed for the brake exhauster when the engine is fitted to a lorry. It is not shown as a seperate part and used to come in a little bag strapped to the blocks.
Roadless63
