Headlamps in grill
Headlamps in grill
Hi guys,
For my 6 cylinder, I would like to mount the headlamps in the grill instead of both sides of the nose cone.
Does anybody has a picture of the mounting plate, to put the headlamps on?
Thank you in advance!
Best regards,
Pascal
Pascal
essex pete
essex pete
Pascal if you don't want to make them why not email the seller and explain the situation. If not then perhaps one of us in UK can buy and send them to you. It would be less complicated to deal direct.
Can these help? http://www.vintagetractorspares.co.uk/v ... _major.pdf
I think you might need to change the lights as well if you have the original fordson or power Major ones. super major lights that fit inside the grill are not as deep in the back to give clearance on the radiator and have diferent mounting brackets to alter the angle of the light and I am not sure if the old light will fit in the cut out in the super major style grills that you will also need.
correct.super6954 wrote:Hi
