Torque ?
Torque ?
Hello to everyone. I have pulled the hydraulic pump from the parts I purchased and new o rings installed. Does anyone know correct torque on the eight bolts that holds the pump together? Also when putting the vertical feed pipe from pump to top back in, I'm putting the pump in from the bottom, should I put the end of it in pump first or top first? Not sure which way will line up the best as I raise pump up from bottom and try to connect it all back together. Thanks for any and all advice.
Gman: 1959 Power Major
if you are going to pull off the raised pto unit and fit it to your tractor it says in my book dont pull the upper right cap screw right out from the 4 mounting bolts. This bolt has a shift fork mounted on it and i guess if it is removed completely the fork falls out. it then states to put a nut on the bolt to lock it in place so that it cant fall out between moving the unit around and re fitting it to a tractor.
Hope this info is usefull to you.
Hi Gerald,
If you are going to put the raised PTO on, you'll also need to change the PTO shaft. The top right bolt won't fall out by itself, the detente kind of holds it in. You can pull it out by hand pretty easily, though, so putting a nut on it is a good idea. Pascal wrote a good article in the Wiki about installing a raised PTO.
Thanks everyone for advice, if you have been on here for any period of time you know I need it. I hope to put hydraulic pump back in tonight if all goes as planned. Putting the raised pto on will be another project added to my list. Looking at it I believe there must be oil leaking:
Reading repair manual it seems I need a seal and as I read it I have to just remove the seal retainer to do this. Again thanks for everyone's advice.
Another torque question. Is there a chart of all the torque requirements, I know the manual shows some on specific jobs but I'm always afraid of stripping something out when reinstalling. Does anyone know torque on the four bolts holding pto shaft in and the eight bolts that hold the bottom hydrulic pump pedestal to the housing? Thanks
In the days of the Major, and when I started in the trade, bolts were "felt" tight and the torque wrench was only used on cylinder heads, big ends and main bearings and the flywheel.
Nearly all other bolts were judged tight by the mechanic. There was also an old saying, "Tight is tight. too tight is 'ping'"! It is rather crude but it worked. Even today I rarely use a torque wrench for ancillary bolts.
The tractor was designed for farmers and their staff to be able to carry out repairs on and those chaps did not have things like torque wrenches. So torque figures are not available in the manual.
I have also seen many older bolts wrung off by people using the correct torque wrench settings, simply because the bolt has "aged" over the years.
As long as it is tight, do not worry.
When you've been doing this for a while you'll get kind of a "fingertip"(rather arm or hand tho) feeling about what's just about right, torquing further after that "feeling" will make the bolt go "ping"
Trust me, been there, done that, learned it...
Working as a bus mechanic nowadays and we didn't even have a torque wrench until today, we bought it just so we can torque the cylinder heads on a Setra on monday next week, everything else is torqued down with either machine(or in the event of a clutch repair, a 3ft extension handle), no snapped bolts so far
This subject of torque of bolts is a good one but maybe we are going Off Topic abit. there is another saying to go with Brians quote
" The ultimate tightness of a bolt or nut is the point just before the threads strip"
I own an air impact wrench but hardly use it as it has no feel to it with regular wrenches and sockets you can feel if it is right or going teribbley wrong and stop before you wreck it.
with the impact the tread or bolt is done before you realise.. When i worked in a dealer workshop my friend used one for everything and broke bolts and stripped loads of threads.
His favorite was metric fine bolts on Belarus flywheels. I spent many hours getting bolts out he wrecked . His comment was I should get one and work quicker. Its like I said though you work quicker but spend more time than me repairing threads or getting broken bolts out so I guess job for job we're even. he had no comment on that!.
If i can think what I was reading at the time there was a rough guide somewhere in a book that i have that gave ideal torque settings for most sizes of bolt . If i find it i'll post the list on here some place.
